AI2622 issue
Hi Everyone, I am using two Pressure Sensors as PM1607 to get Tank Level using Pressurized Configuration, One at Top and One at Bottom. I am only receiving
analog Input on One Channel as my two sensors are already connected to the card. If I am connecting the bottom sensor to channel 1 its green light on card is blinking whearas the
top sensor connected on Channel two its green light is stable. I have already checked with by interchanging sensors. My sensors are not faulty. Can you explain me what I could
check and correct in this and what does overflow/underflow means.
overflow/underflow means, that the measured physical value is out of rhe measurement range.
The range depends on the setting / usage of the sensor signal (voltage or current signal).
Please have a look here in the online help for details:
Best regards.
