One of our customers encountered a situation where the CPU core mismatch error popped up when starting ARwin.
Could you please tell me where this can be checked and configured?
CPU is 5PC900.TS77-02
Thank you~
Thank you~
when installing ARwin the configuration tool (depending on the settings within the configurator) reserves one core for the realtime runtime
This means that Windows no longer gets access to all cores of the processor.
If the configured core numbers do not match the real and reserved core numbers this error arises. Normally this error does not arise “out of the box” and I wonder what was done to force this error. typically this would arise when the APC was replaced with a different model and the CF card containing Windows was simply plugged to the new APC
You can try to call the “ARwinconfigurator” located in the ARwin setup folder, then save and close the configurator followed by a restart of the APC
Then the configuraot should adjust the core numbers and the error should be gone.
best regards
Oliver
