kuma1p
(Priyank Kumar)
April 17, 2026, 6:41am
1
At one of our customer, we are getting the following error in an ACOPOS P3 dual axis drive.
9092: Power stage: Temperature sensor 5: Stop limit exceeded
Both the axis are reporting this error and upon physical inspection the temperature for both the axis is normal.
What can be the issue?
I would assume the output current from drive exceeds its specification.
Did you trace the error situation ?
E.g.
Trace
214: CTRL Current: Actual stator current quadrature component
219: CTRL Current: Actual stator current direct component
with pre-trigger on
469: Messages: Status error record available
additionally a Systemdump / Network Command Trace is helpful
(edit: Trace from both axes is needed )
in addition to what Christoph said, I suggest to also add this ParID to the trace:
1538: Power stage: Temperature sensor 5: Temperature
We will see if the temperature corresponds to the current values.
kuma1p
(Priyank Kumar)
April 17, 2026, 12:28pm
4
Thank you team for your response. The reason for the issue was that the fan of the drive was not working. They replaced it with a new drive and now the machine is running fine
