I am troubleshooting a hardware issue with a B&R Automation PC 910 (APC910) running with a 5AC901.BUPS-00 UPS module, and I am looking for community advice on whether this system unit is completely dead or salvageable.
The Background:
The machine was powered off completely for 6 months. During this storage period, the UPS battery suffered a severe chemical failure, discharged fully, and leaked corrosive material.
Current Symptoms:
The Power LED is solid RED the moment 24V DC is applied.
The HDD orange status light blinks for a split second (a millisecond) and then completely turns off.
There is no output to the monitor via the DP port, VGA, or DVI connectors.
There is no power being delivered to connected USB devices (the mouse and keyboard remain completely unpowered).
It is impossible to access the BIOS menu.
What We Have Tried So Far:
Disconnected the UPS: We removed the external UPS connection completely and attempted to power the APC910 using only a clean, standard 24V DC supply. The symptoms did not change.
Checked CMOS: The CMOS battery has been verified, and the voltage level is good.
Note on storage: Please note that there is no CFast card present or installed on this system unit during these tests.
from what you described, it could be a defect unfortunately, if the system does not respond to power or reset button.
See here for some more details:
As the battery broke down, maybe the UPS electronic has a failure too, and blocks the start of the system when supplying power… honestly spoken I don’t think so, but maybe it’s worth a try to remove the UPS interface card.
