I’m not sure how many people are keyboard shortcut in AS Code. I found that the default shortcut for block comment (* *) is mapped to C/C++ comment /* */ and it seems not corrected for many versions.
To correct it open file C:\Program Files\BRAutomation\Automation Studio Code\resources\plugins\st-lsp-extension\language-configuration.json and modify line 6 to "blockComment": ["(*", "*)"]
To trigger this, the shortcut is Alt+Shift+A.
I know that B&R practice not recommend using it:
But if you are using “line comment” in .var file. you will get:
