Does anyone have the INTERACT softWare?
There was a Ronchi’s filler HMI could NOT restart after an unexpected power failure. After diagnosis HMI (Provit 2000) B&R’s INTERACT program could not restart because security key is not readable (the ibutton key is damaged). Can anyone help me? I have the project file.
I am afraid that it is not really possible to help here. The message states that the security key did not unlock a certain module from Interact
This is typically (as you already wrote) when the Interact dongle is missing or damaged. This dongles are no longer available for purchase (since many years now)
Interact was no B&R program (made by a company called “CTC”) and was only distributed by B&R.
Please let me know if you would need Interact software - I can take a look if I can get it. Nevertheless this will not help as the security key is mandatory to unlock runtime functions on the device running Interact Runtime
best regards
Oliver
Thank you Oliver,you can send this software to me and I will have atry.
I will send you a private message containing Interact but as mentioned this will not help.
It is not possible to bypass the security key
best regards
Oliver
Thank you Oliver! I have got the interact6, it’s a runtime install files. Could you pls give me the “MNET” and “P2000” dirvers install files in Interact for B&R, V5.2 or V6.0 is Ok.
With Best Regards!
JADE CHEN
I do not know what P2000 is but I zipped all drivers I could find:
drivers.zip (5,3 MB)
best regards
Oliver
Thank you Oliver! I think the P2000 driver is the Interact B&R PROVIT 2000 Device Driver, version maybe BR-E0001-520. If the installation package can be found, regardless of whether it can be found or not, thank you very much!
With Best Regards!
Hi, here is driver P2000 included, but Version
P2000.exe
P2000.exe
B&R PROVIT 2000
P2000
BR-E0001-500
@ FF 0 4
DRIVERS.zip (7.0 MB)
Good Luck
Hermann
