Encode/decode with AES algorithm
Does anyone have exprience with encoding / decoding data with AES algorithm?
I am looking for a sample code.
Thanks for informations.
Lothar
I haven’t ported AES until now, but here’s a C based reference implementation that should be easy to port to the PLC (I used other algorithms from that page in the PLC):
Thanks for the immediate reply. I’ll try it.
Hi again,
I just saw that the AES basic implementation of the link above does not support AES GCM mode, and uses malloc which makes it maybe a bit harder to port it to AR.
So maybe this one is worth a look when needing AES GCM (I just had a quick look into the code, so I can’t promise but it also looks promising in direction of porting it to AR):
HI @Lothar_Waibel , would be great if you provide us feedback how did you finally solved your issue. Thanks a lot.
