I’d like to ask for your help again. ![]()
I’m trying to establish a Powerlink connection between two projects with different Automation Studio (AS) versions. According to the help documentation, the issue is that I need two identical configurations to establish the connection between the two PLCs.
In AS 4.12, I created a channel for the structure MpAxisBasic (for testing purposes with motion parameters) as OCTET[900]. I connected this in the I/O mapping to a global variable used in the code, and everything works fine.
In AS 6.3, I tried to set up the same configuration, but I’m getting the following error:
Error number: 6735
“Type mismatch: Cannot connect variable ‘gGlobalAxisData’ to ‘%QO.“X20CP1686X”.IF3.AxisData’”
Does anyone have a clue what I might be doing wrong?
