# How to setup communication on a Vehicle-CAN
**URL:** <https://community.br-automation.com/t/how-to-setup-communication-on-a-vehicle-can/2778>\
**Category:** Controls & Vision\
**Tags:** automation-studio, fieldbus, plc\
**Created:** [April 4, 2024, 10:05am UTC](https://community.br-automation.com/t/how-to-setup-communication-on-a-vehicle-can/2778 "2024-04-04T10:05:10Z")\
**Showing post:** 5
**Author:** ![marcusbnr](https://dub1.discourse-cdn.com/brcommunity/user_avatar/community.br-automation.com/marcusbnr/32/256_2.png) [@marcusbnr](https://community.br-automation.com/u/marcusbnr)\
**Post date:** [April 4, 2024, 12:26pm UTC](https://community.br-automation.com/t/how-to-setup-communication-on-a-vehicle-can/2778/5 "2024-04-04T12:26:24Z")
Automation Studio doesn’t support DBC files unfortunately. To use CANopen, you’ll need an EDS file. Automation Studio also supports some other file formats (which can be imported using Tools → Manage 3rd-Party Devices), but EDS is the most common one, and one I know works with CANopen.
Additionally, I believe that DBC files are used with CAN, not CANopen. CANopen is a communication protocol which uses the CAN network but adds additional layers on top of it. If you want to use plain CAN communication, you’ll need a CAN interface instead of a CANopen one. Some controllers have this built in, but it’s also available as an X20 IF module (X20IF1072/X20IF2772) or an I/O slice (X20CS1070/X20CS2770).
If you want to use a DBC file, you could write a program to extract the information from it and then read the registers it provides using the [ArCan library](https://help.br-automation.com/#/en/4/libraries/arcan/arcan.html). This is something I’ve looked into in the past. It would take some development work but it’s doable.
I also see J1939 mentioned in your screenshot. Does this device communicate using J1939? If so, you can use [mapp J1939](https://help.br-automation.com/#/en/4/mapptechnology%2Fmapp_services%2Fmpj1939%2Fmpj1939.html) with the CAN interface.
_[View the full topic](https://community.br-automation.com/t/how-to-setup-communication-on-a-vehicle-can/2778)._
