List binding + application modules: upgrading project from AS4 to AS6
Hi, I’m currently upgrading a project from AS4 to AS6. This project is hyper modular and uses many application modules. The HMI uses many list bindings where each selection points towards a different modules. This is no longer supported as described here in the help. I have hundreds and hundreds of datapoints linked via list binding. Has anyone experienced the same issue and how did you fix it ?
Topic was pinned by moderator to increase chance that some will help here.
Tagged as a support-ticket, @francis.pion would be great if you update us with final solution you have selected for your issue.
Hi Jaroslav,
I coded a ListBinding function block that provides similar functionnality so it takes code from .binding to .st. It’s definitely not ideal, but it works.
Thanks for update,.. I really appreciate it.
