Max number of users with MappService MpUserX
I am using MpUserX block to create users, user management etc. It was asked of me if there is a limit to how many users can be created.
Does anyone know of any practical limit that exists?
Thank You
Hi!
With MpUserX, there is currently no known limitation of how many users/roles can be created. I could also not find any information in the documentation of the User/Role System…
So, I would assume there is no hardcoded limit. However, as with most systems, adding more users may slow down the login process, as more users exist and would need to be checked. I can however not give any values for this, as I’ve not tested that for a long time (~8 years).
As for practical limits, that depends. If you use mapp View, with the UserList Widget, it may be simple to manage users, but there are no “bulk operations”, so more users usually means more maintenance effort. I can unfortunately not say how the interaction with the widget really works when you have e.g. hundreds of users.
If you use the MpUserXManagerUI function block, creating new users might still be simple, but managing or deleting existing users will become increasingly difficult, since the list this FB provides can only display a maximum of 20 elements, before you have to scroll (and does not provide “Search/Filter” logic to find specific users). You can imagine this FB like a book… You can see one “page” of users, then you have to flip the page to see the next set.
Now, if you have access to systems like Active Directory or 389DS, you could use these to manage your users, where you have more possibilities regarding search/filter, bulk operations, … However, these systems usually require an external PC, as Active Directory primarily/only runs on Windows, and 389DS primarily/only runs on Linux.
Long story short:
It depends on your actual use case, and which benefits/drawbacks you are willing to accept. Since MpUserX supports two modes, I’ll throw in a short list comparing them… Please note that a combination of both modes is also supported, though it brings in some more points to consider.
MpUserX/User-Role-System:
  • :check_mark: Limited only by disk/RAM space on the PLC (possibly limited at integer cutoff points like 32767/65535 or 2177483647).
  • :cross_mark: Cannot be syncronized across machines. If multiple machines need the same users, they need to be manually “copied over”.
  • :cross_mark: Does not provide search/filter or “bulk” operations.
  • :check_mark: Runs only on the PLC, with no external service.
MpUserX connected to Active Directory / 389DS:
  • :check_mark: Limited only by disk/RAM of the server system.
  • :check_mark: Single source of truth. Multiple machines can be connected, and users are “shared”, no synchronization effort needed.
  • :check_mark: Provides search/filter and possibly “bulk” operations for easy editing.
  • :cross_mark: Requires an external service for user authentication, if this service is unavailable, logins won’t work, or may take longer.
Michael,
Thank you for this detailed reply. This gives me some things to think about moving forward.
