I’m not sure if this is the cause (or even if it belongs to your issue), but I see in your client certificate an unusual combination of the “DNS” parameter and an IP address:
As far as I understood, if using an IP address the parameter “IP:” has to be used, if using a hostname the parameter “DNS:” has to be used inside the certificate.
I took the screenshot during testing and might have used an older version. It definitely has to be IP:…
But since I had already tested it, it did not solve the problem.
okay thanks.
As the root error message “BadCertificateUriInvalid” points directly to the IP/DNS configuration, I’ve no other idea by now what to check else.
Another common certificate validation issue is based on “unsynchronized clocks between client and server”, but I’m not aware of the error message in that case - nevertheless I would recommend to check that.
Let’s wait, hopefully someone with more experience in direction of certificates then me has more ideas…
it looks like there is missing the URI for mappView in your certificate, take a look here: OPC UA - Creating a client certificate, you can add direct at the URI: urn:/BR/HMI/mappView@local , delete the default one.
