Problems with Widget "TextPicker"
Hi everyone,
Since switching to AS6 (6.5.3.22), I’m having problems with the TextPicker widget (widgets.brease.TextPicker).
First, I scroll to a new text.
When I then select a different text with a click, the widget selected two texts at the same time.
I’m using mappView Version 6.8.0
Has anyone encountered similar problems or found a solution?
Thanks in advance.
Hi Leon,
Thanks for sharing the details. Based on your description, here are a few troubleshooting steps that may help narrow down the issue:
  1. Verify whether the double-highlight is only a visual issue by monitoring GetSelectedIndex or SelectedIndexChanged. Actions and events
  2. Test with submitOnChange = false and manually trigger SubmitChange to determine whether the behavior is related to the automatic submit timing after scrolling. Actions and events
  3. Try reproducing the issue in a different browser or at a different zoom level
  4. Recreate the screen using a default TextPicker configuration without custom styling (such as itemActiveBackColor or other style overrides) to rule out a styling or transition conflict.
  5. If possible, capture a short screen recording showing the exact scroll-and-click sequence that leads to the issue, as timing-related behaviors can be difficult to diagnose from screenshots alone.
If the issue persists and it is ultimately determined to be a bug, please contact your local B&R Product Support team. They can assist with opening a formal support case and gathering the necessary information for further investigation and potential bug tracking by the development team.
Best,
Rosh
Coustomer has reached out to local Support. Topic is now known as CASE-102027
“TextPicker - Optical issue “double” selected after scroll”.
For me it looks like an optical issue. MappView 6.7 does not show this behaviour, so i think its a not intended behaviour in 6.8. . I will provide updates as they come from support.
