Hello everyone, I would like to remove the password for this; how can I do that? I haven’t been able to find where I need to go to cancel the password.
the simplest way should be using the ‘Anonymous Token’ (see check button of above dialog).
Of course, this becomes a safety issue in a “real” machine.
The ‘correct’ way would be to add a user with role ‘BR_Engineer’: Preparations for using mapp Cockpit
Thanks you, it worked.
