Scroll synchronization Mapp View 6.8.1
Function scrollLinkXRefId and scrollLinkYRefId for tables does not seems to work anymore with mapp view version 6.8.1. With older versions (6.6) it works.
Hi @SemVerhaege ,
I really hope our Community is a place for sharing ideas and not bugs + we have some guidelines for that:
If you found a bug in an official B&R software, please report this directly to your local B&R Support team. The B&R Community is not the official channel for bug reporting. The exception is for bugs related open-source developments within the community itself. The same restriction applies for quality topics.
Right..but I believe @SemVerhaege has not used the community for reporting issues, more likely for asking if a problem is known and a workaround is available. @SemVerhaege since I have not found similar report, please use officail support channel for reporting and update us with findings, thanks a lot :slight_smile:
Hi @SemVerhaege ,
I see that our colleagues have reported your issue in our Support channel, which means they have reviewed your case and reproduced the problem: mappView: ScrollLinkXRefID doesn’t work as expected in V6.8.x. With V6.7.0 of mappView (and without any other modifications in the project), the scrolling is working fine.
As I mentioned in previous posts, your time is valuable. When you encounter a clear issue like this, please report it to our regional Support team and attach the project file along with a few steps to reproduce the problem. After that, you can continue with your work.
