SDM Not Opening in VC4 – HTTP Error 404 on Controller and Simulation
Hello everyone,
I am facing an issue while trying to access SDM through VC4. SDM is not opening either when running the project on the controller or in simulation.
The following error is displayed when trying to access the SDM page:
“There is a problem with the page you are trying to reach and it cannot be displayed. HTTP error code: 404.”
I have configured the SDM URLs in VC4 as shown in the attached configuration screenshot:
  • English: http://localhost/sdm-vga/vga.cgi
  • German: http://localhost/sdm-vga/vga.cgi
  • Russian: http://localhost/sdm-vga/vga.cgi
AS version - AS 6.5.1.7
However, accessing the page results in the attached HTTP 404 error. I even tried IP addresses in place of localhost. The issue occurs in both controller operation and simulation.
Both the error screenshot and VC4 configuration screenshot are attached for reference.
Hi there,
maybe it’s as simple as this: the SDM defaults to OFF and has to be explicitly enabled:
Hope that helps
Hello Michael,
The SDM is already enabled in the controller config. and still facing the same issue
Best Regards,
Can you also check the web server config? It defaults to https, you would want to set it to either http or http+https then
I have already tried that and currently the web server config is http, but still facing the same issue
just trying to understand the issue better:
is it just happening using VC4?
Does the SDM link work when opening with an external browser using the IP address of the PLC?
Yes SDM works in the browser correctly external browser using the IP address but unable to access on controller or in simulation(VNC viewer).
Try a fixed IP address or enable DNS, see help.
The SDM starting address must be defined at Index 1, see help.
I tried after enabling DNS and keeping the index 1 as well as the putting simulation/controllers IP instead of localhost also but still i am unable to access SDM.
I’ve just tried the empty project with X20CP0484-1 in simulation. I’ve followed the help and it’s working for me. Can you do the same?
Hi @Ayush_Mishra any update there? I think procedure how to enable it was clearly descirbed by Pavel.
These all steps were already followed by me before and I have also tried putting IP address (127.0.0.1) for simulation instead of local host but still the error 404 occurs and unable to access SDM.
Attaching a video showing all the configurations and issue.
SDM Issue.zip (7.6 MB)
It works for me with 4PPC650.101E-020 as well.
The differences I can see in the video are:
  • index 0 in the Text Group
  • AS version
Could you try an empty project as I did?
I tried with new empty project but still facing the same issue without index 0 in text group. I was facing in AR 6.6 & 6.7 also so, I updated to the 6.8 but still the same issue persists.
What does “still facing the same issue with index 0 in text group” mean? Do you have index 0 in the text group? Can’t you delete it and have the first index be 1?
Sorry It was a typo, I meant without index 0. I removed it and new test project only have index 1.
So the only difference is that you are using AS 6.5, whereas I am using AS 6.7. Could you please try it with the newer AS?
If that doesn’t help, please contact your 1st level support.
