Virtual Master Axis Not Generating Master Ready Status in MpCamSequencer (ACOPOS D1 as SDC Slave)
Hello Team,
I am using an ACOPOS D1 drive as the SDC slave axis, with a Virtual Axis configured as the master axis.
Both the slave axis and the virtual master axis are powered on and homed successfully. Additionally, both axes can execute Move Velocity commands without any issues.
However, when using the MpCamSequencer function block, only the Slave Ready status becomes active. The Master Ready status for the virtual master axis never becomes TRUE, which prevents the cam sequence from starting.
When I use the ACP10 MC_BR_AutControl function block with the same master and slave axis configuration, the application works correctly and the cam Sequencer runs as expected.
Could you please advise why the Virtual Master Axis does not generate the Ready status when used with mappAxis MpCamSequencer, while the same setup works properly with ACP10 MC_BR_AutControl?
Any suggestions or experience regarding this behavior would be greatly appreciated.
Best Regards,
Chetan Patel
Hi @patelc ,
I mean what I have to say:
  1. Do I know if you are using legacy ACP10 or mapp Motion? NO
  2. Do I know which motion version you are using? NO
  3. Have you attached SystemDump to see if you have helpful messages on motion logger or network command trace? NO
  4. Do I know if MpCamSequencer, in your prj, has reported an error? NO
  5. Do I know if you are using MpCamSequencer in correct way? NO, I don’t see your task where you call that function block
  6. Do I know in which PLCopen state (disabled, standstill, homing, stopping, …) are your master and slave axes before you call MpCamSequencer? NO
  7. I’m sure there is a typo, because so far on mapp Motion and legacy ACP10, on MpAxis library I see only MpAxisCamSequencer and not MpCamSequencer. Are we talking about the same function block? or you are using an user library?
I’m 100% positive if I prepare a demo prj just focus on MpAxisCamSequencer that works so, as always, more information you provide faster is the answer.
When you have time have a look at this post: CamSequencer base code for test or study
Hi @patelc what is status of your issue? can you update us?
Hello @valerio.manenti ,
I have created a sample project with this configuration to help reproduce the issue.
Please find the attached project file for your reference.
https://abb-my.sharepoint.com/my?id=%2Fpersonal%2Fchetan%5Fpatel1%5Fin%5Fabb%5Fcom%2FDocuments%2FAttachments%2FCamAutoMate%5FSample%2Ezip&parent=%2Fpersonal%2Fchetan%5Fpatel1%5Fin%5Fabb%5Fcom%2FDocuments%2FAttachments
Thanks & Regards,
Chetan Patel
Hi @patelc ,
I have requested the access to that folder.
Hi @patelc ,
I can’t debug and fix the issue in your prj; please call our Support team in your country for that.
For what I see, there is an error in your instance of MpAxisCamSequencer:
As an example:
hello @valerio.manenti,
Okay, thanks for the information.
