X20AI8039 filter
I found, that in my project I can’t set the FIR option in AS for X20AI8039.
Is there also someone who can explain the function of filters? Where is defined the FIR for the lenght and the weights?
Hi @NovotnyJ ,
Which hw upgrade are you using?
X20AI8039 | B&R Industrial Automation
I have installed the latest one but I still see your issue:
I’m sure the documentation for FIR is under construction Data sheet X20AI8039 | B&R Industrial Automation because I don’t see any description of that.
From AI: On the B&R X20AI8039 temperature and resistance measurement module, the FIR (Finite Impulse Response) filter is a configurable software-based digital low-pass filter used to smooth out high-frequency noise and electrical interference from your analog input signals
How To Design an FIR Filter: For Beginners
I checked another module X20AI744:
You have to change, in this case, function model from default to advanced filter for selecting FIR:
Sincerely no idea how to configure FIR filter on X20AI8039 module.
@valerio.manenti I used 1.1.1.1 and try to update for 1.1.1.2 because it’s littlebit new, but there is still the problem.
I know the FIR, but don’t know how it’s implemented - order, weights,… And the SINC are only the weights and order for FIR. But there is some info about it? Something like frequency characteristics, etc.
Ok just for a moment forget your X20AI8039 and check the documentation for X20AI1744: Data sheet X20AI1744 | B&R Industrial Automation
On the section 2.3.1.3 FIR filter you find more details about that filter.
Hi @NovotnyJ ,
Please pause your investigation into FIR and X20AI8039 for now. I have contacted our R&D team and expect to have an update by early next week.
Thanks for info :blush: I also try to contact my local br support.
Hi @NovotnyJ ,
unfortunately R&D has confirmed that the not working setting is a BUG, and they ask us to create a CASE for this. They are also going to review the FIR filter documentation. Please ask our Support in CZ to forward the CASE to L2.
Thanks Jan for your feedback, this is the only way we can improve our products.
The CASE was created. We’ll share an outcome when it’s available.
