X90 grounding
Customer asks if you have any good practice for grounding X90, e.g. CANopen CMC header, X90 housing, etc.?
Is it sufficient to connect it only to vehicle frame, or do you use any special antistatic strap?
Hi Marcin,
From my point of view I can only refer you to the X90 manual. All related to grounding connection is documented in X90 mobile System User’s Manual.
Chapters 6.4 and 6.6 could be interesting for you.
