I am getting a boot error in ARSim due to the following lines of code related to ArEventLogWrite:
strcpy ((char*)ArEventLogWrite_0.AddData, str); |
ArEventLogWrite_0.AddDataSize = strlen(str)+1; |
ArEventLogWrite_0.AddDataFormat = arEVENTLOG_ADDFORMAT_TEXT; |
I was wondering if anyone know what is the issue? I have defined str as a global variable:
char str=“test msg”;
Attached the whole program:
#include <bur/plctypes.h>
#include
#ifdef _DEFAULT_INCLUDES
#include <AsDefault.h>
#endif
// amount of memory to be allocated for heap storage must be specified for every ANSI C++ program with the bur_heap_size variable
unsigned long bur_heap_size = 0xFFFF;
void _INIT ProgramInit(void)
// Insert code here
//arEventLogStr = “this is additional info”;
//ArEventLogWrite_0.AddData = &arEventLogStr;
void _CYCLIC ProgramCyclic(void)
switch (Step)
case 0:
// Add Start Condition if nessesary
Step = 5;
break;
case 5:
ArEventLogGetIdent_0.Name[0] = 'a';
ArEventLogGetIdent_0.Execute = false;
ArEventLogGetIdent(&ArEventLogGetIdent_0);
Step = 10;
break;
case 10:
ArEventLogGetIdent_0.Execute = true;
if (ArEventLogGetIdent_0.Done)
Ident = ArEventLogGetIdent_0.Ident;
Step = 30; // Write
else if (ArEventLogGetIdent_0.Error)
if (ArEventLogGetIdent_0.StatusID == arEVENTLOG_ERR_LOGBOOK_NOT_FOUND)
Step = 20; // create
ArEventLogCreate_0.Name[0] = 'a';
ArEventLogCreate_0.Size = 65535;
ArEventLogCreate_0.Persistence = arEVENTLOG_PERSISTENCE_PERSIST;
ArEventLogCreate_0.Info = 0;
ArEventLogCreate_0.Execute = false;
ArEventLogCreate(&ArEventLogCreate_0);
else
Step = 255; // error
break;
case 20:
ArEventLogCreate_0.Execute = true;
if (ArEventLogCreate_0.Done)
Ident = ArEventLogCreate_0.Ident;
Step = 30; // Write
else if (ArEventLogCreate_0.Error)
break;
case 30:
ArEventLogWrite_0.Ident = Ident;
ArEventLogWrite_0.EventID = 536870912;
ArEventLogWrite_0.OriginRecordID = 0;
//ArEventLogWrite_0.AddDataSize = 0;
//ArEventLogWrite_0.AddDataFormat = 1;
//ArEventLogWrite_0.AddData = 0;
ArEventLogWrite_0.ObjectID[0] = '2';
ArEventLogWrite_0.TimeStamp = 0;
ArEventLogWrite_0.Execute = true;
ArEventLogWrite(&ArEventLogWrite_0); // synchron fub call
ArEventLogWrite_0.Execute = false;
Step = 40;
break;
case 40:
break;
void _EXIT ProgramExit(void)
// Insert code here
I found the error, need to set the str address instead of strcpy:
ArEventLogWrite_0.AddData = (unsigned int)str;
The whole program below:
#include
#endif
// Insert code here
switch (Step)
case 0:
Step = 5;
break;
case 5:
Step = 10;
break;
case 10:
Step = 30; // Write
else
break;
case 20:
Step = 30; // Write
break;
case 30:
ArEventLogWrite_0.ObjectID[0] = '3';
Step = 40;
break;
case 40:
break;
// Insert code here
Good that you found it by urself. Can you mark the Thread as solved, it works also on your own posts.
