Problem Statement:
We wanted to develop faceplates for the respective libraries blocks. So we are using information models, Each library has its own nodeset files and each library bock has nested blocks i.e object in objects. When we instantiate the library blocks in the program we were requred to manually write the nodesets and indeces/ UA Type definations for the resepective instance and also for the the nested instances, which was very difficult, time consuming and error prone job.
Solution:
We developed an application which does this job for us.
Below are the nodeset files in our project
We enabled the required tags
Place the tool in the root folder of the project.
run the tool and its done.
For usage tracking purposes, please DM me and I will share the software with you, I hope this helps.
Thanks and regards
