CyberSecurity - CheckList
Hello
does it exist a manual or a checklist of tasks to be performed to secure a B&R PLC for CRA?
For example:
  • Check OPC UA server does not allow anonymous connections
  • Check FTP connection is secured
  • Check connection to PLC is secured
Thank you
Marco Sartori
Well not exactly a checklist but B&R provides system‑hardening guidance, training, and best‑practice documents that map well to the requirements of the EU Cyber Resilience Act (CRA) here
https://www.br-automation.com/en-gb/academy/online-courses/axis-coupling-with-mapp-motion-soc4171/
For OPC UA server you can do things like
  • Disable anonymous login
  • Enforce certificate‑based authentication.
  • Enable encryption (TLS).
  • Restrict namespaces and exposed variables.
  • Limit endpoints to required security policies only (e.g., Basic256Sha256).
    For FTP you can
    • Use FTPS (TLS‑secured).
    • Restrict user accounts and directories.
    • Disable write access unless strictly necessary.
      And for PLC connection you can
      Use Secure Remote Maintenance or Automation Studio Secure Connection.
    • Disable “online change” for unauthorized users.
    • Restrict programming ports to engineering VLAN only.
thanks Nicolas
is the correct link?
Marco
Woops no, this is the correct link.
https://www.br-automation.com/en-gb/academy/online-courses/cyber-security-basics-and-system-hardening-with-automation-studio-soc9901/
Its an online course but I also realized its a paid online course we offer
Unfortunately what will be completely CRA compliant is still in the works so I cant provide much more information for now
