Dynamic Runtime Certificate Generation and Replacement Using ArCert
Introduction
This article describes how to generate a certificate at runtime and replace the default certificate using ArCert function blocks.
Delete Default Certificate
First, delete the default certificate using:
  • ArCertDeleteOwn
Generate New Certificate
After deleting the default certificate, generate a new one using:
  • ArCertGenerateX
Important:
  • The certificate name and key name must be the same as the default certificate
  • The names must include the file extension, for example:
    • CertName.cer
    • KeyName.key
Otherwise, the TLS configuration will not be able to refer to the new certificate.
Optional: Export Certificate
Export Process
The new certificate can be exported using:
  • ArCertExportOwn
Then use FileIO function blocks to write the exported data:
  • FileCreate
  • FileOpen
  • FileWrite (point to exported data from ArCertExportOwn)
  • FileClose
Storage and Transfer
  • The certificate can be exported to CF
  • It can then be copied to the device via FTP
Final Steps
After completing the steps:
  • Change the IP address of the PLC and/or perform a warmstart
Note:
  • Default settings remain valid until a warmstart is executed
Usage
After that, install and configure the new certificate in:
  • Automation Studio (AS)
  • PVI
  • or wherever required
Created based on solution provided by @Thomas.Haindl here Automation Studio 6: Encrypted ANSL Communication with TLS → ANSLS – Problems with Dynamic IP Change and Trusted Certificates - #12 by Thomas.Haindl
