As already described in this article, here’s a more detailed description how to implement masked input with a NumPad keyboard (as with the Password widget on an alphanumeric keyboard), for example if only a PIN is wished for user authentication.
Add the masked password font as attached in the above article to your AS project. It simply converts any numeric value to a “*”.
Add a new style (called “maskedInput” in my case) and set the new font to the “valueFontName” property of the Numpad widget (in my case the custom “widgets.MyStyle.Numpad”.
Place the NumericInput widget on the content and set the property “numPadStyle” to the new style “maskedInput”.
Result:
(you can remove the “min” and “max” fields on the NumPad of course).
