Initial ValueChanged events vs. compound widget
It seems that the option Initial ValueChanged events, which works perfectly with common events, does not work for events within a compound widget.
In my compound widget, a LocalProperty bound to a variable is defined with a dedicated event and action. In the EventBinding, the result of the action is read, and actions are performed accordingly.
Could you suggest a better syntax to achieve an initial update for this event?
Thank you.
Regards
Michal Malek
Hi Michal,
is for the content which uses this compound widget preCaching enabled?
I noticed, that preCaching triggers initial events.
Maybe you can use OnWidgetsReady event of compound widget.
See B&R Online Help (br-automation.com)
This event is triggered when the compound widget is loaded for the first time.
Hope, this helps you.
Sincerly Simon :slight_smile:
Thank you, Simon. Now it rus perfectly.
Hi Michal, is it topic solved/closed? If so, please mark a reply from Simon as a solution. Thanks.
