Library does not appear
HI, I have a simple question as I’m still learning how to use Automation Studio. I want to use the MTBasic library but when I try to add it to my project it does not appear in the list of the B&R libraries. I have installed more than one version of the library.
Hi Snide,
The MTBasics library is part of mappControl. If you select a mappControl version in Project->Change Runtime Versions, you can then select an MTBasics version by expanding the version list with the Advanced option:
