Mapp Sequence Integration with Mapp view
I was having an application where I am using mapp sequence, now I am unable to view sequence on edit area and also sequencer table not showing any image.
Please let me know the process of adding mappview with mapp sequence.
Hope for the answer soon
Question seems to be very general, I think the best is to start with getting started B&R Online Help and use case B&R Online Help. You can also check mvHighlight project in Sample folder of Automation studio installation.
Can I add steps into the existing sequence in edit sequencer area from sequencer table (sequencer table items) in Mappview using Drag and Drop, If yes then how ?
hope for your reply soon !
Closed as a unsolved
