The documentation of Automation Studio 4 doesn’t give any information about the size of the trace buffer size ; I manage to find it out (32768 Bytes, like the standard Trace-buffer tool in AS).
Tracing 4 channels, I meet the problem that my Tracing time isn’t enough (~ 2 seconds when I need ~15), and sample rate needs to stay at its current value ( 400µs)
So here my question: is there any way to increase the buffer size?
Thanks for the answer, this is even easier as the previous answer from Tommi (which seems to work) ! I try this in the next days and will mark it as the solution if this works.
I’m just wondering if you have an explanation for the difference in the maximum value between the documentation (32768) and your own experience (131072)? Outdated documentation?
I did not remember putting this subject on solved, did anyone do it for me maybe?
So I could try the solution of Tommi with CoTrace, and got it to work, but only for software variables.
I am not able to record ACOPOS variables ; I have the impression to respect the syntax described in the documentation but I keep getting an error -2124414954 from the function CoTraceConfigLoad (invalid configuration)
Were you able in the past, Tommi, to record ACOPOS variables? What were the common sources you got from this error number -2124414954 ?
