Hi
We are currently using OnlineCharts in mappView to display process data. Is there an easy way to “freeze” the current chart for better analysis? We were thinking of a “pause” button or something similar. While we could implement this using the LineChart widget, it’s not a viable option due to the necessary software changes required for the data arrays.
We are looking to implement a simple “scope” for predefined variables, as mappCockpit is not very user-friendly for our technicians. Additionally, it’s often difficult to access the machines due to the IT policies of our customers.
you prop. might want to look into the OnlineChartHDA … While this widgets is intended to be used with OPC-UA HDA functionality, it behaves pretty much similar to the OnlineChart, if no HDA is configured. OnlineChartHDA however has a “freeze” function to better analyse the data.
