PPC50 How to sync PLC time with terminal time?
Here is two video:
It work ok on one video and doesn’t on the second one.
first vdeo (works) Time_OK.mp4 - Google Drive
second video (doesn’t)
Time_not_OK.mp4 - Google Drive
It’s all the code I send to you: sometimes sync work, sometimes doesn’t. I’ll try to update terminal firmware version soon.
I’ve updated the terminal to firmware version 1.2. The problem with wrong time zone was eliminated. Time synchronization works as well.
Note:
The time sync doesn’t work when time difference is relatively low, as you can see on the video Time_not_ok.mp4. I’d like to know if it (time difference) can be changed?
I’m sure it will work with low time difference as well. time synchronization is then done with small steps.
