Hi Martin,
Here’s a short example for changing ASCII strings to uppercase (see attached sample task):
- check byte for byte of the whole string
- if the value is between hex 61 and hex 7A, then substract hex 20 (which is the offset between A…Z and a…z in the ASCII table)
- if not, leave it as it is
UpperCase.zip (1.5 KB)
