Virtual Master Axis Not Generating Master Ready Status in MpCamSequencer (ACOPOS D1 as SDC Slave)
Hi @patelc ,
Any suggestions or experience regarding this behavior would be greatly appreciated.
I mean what I have to say:
  1. Do I know if you are using legacy ACP10 or mapp Motion? NO
  2. Do I know which motion version you are using? NO
  3. Have you attached SystemDump to see if you have helpful messages on motion logger or network command trace? NO
  4. Do I know if MpCamSequencer, in your prj, has reported an error? NO
  5. Do I know if you are using MpCamSequencer in correct way? NO, I don’t see your task where you call that function block
  6. Do I know in which PLCopen state (disabled, standstill, homing, stopping, …) are your master and slave axes before you call MpCamSequencer? NO
  7. I’m sure there is a typo, because so far on mapp Motion and legacy ACP10, on MpAxis library I see only MpAxisCamSequencer and not MpCamSequencer. Are we talking about the same function block? or you are using an user library?
I’m 100% positive if I prepare a demo prj just focus on MpAxisCamSequencer that works so, as always, more information you provide faster is the answer.
When you have time have a look at this post: CamSequencer base code for test or study
