What is the best way of Induction motor speed control using loadcell output
We are using now
Motor velocity= Motor velocity +Loadcell values *(0.01 or 0.1)
Motor velocity in mmps.
Loadcell value output 5ms.
software (Tension action) running @ 4 ms.
Hi Veeresh, you might get better answers if you can provide us with some more information about your problem. For example, how are you controlling your motor? What I/O module are you using to read the load cell? What is wrong with the method you are using currently?
Hi @veeresh.suranagi do you still need help with this topic?
No.
Thanks for your support.
