Access denied when using usb-port on T50 panel with DevLink
I’ve have it up an running now. Thank you for your help. I changed USB-stick and tried again and then it worked with my setup.
During my tests, I noticed that it will create a device and you’ll get devlink return 0 if you connect a mouse with usb as well. But nothing else works with it. So that can be good to keep in mind depending on your application.
