Hi Tullio,
it was a bit more complicated than I thought but I have a working example for you.
The tricky part is to read out the TextID into something that can read the actual text not just the TextD.
The basic idea is to display the SVG without text labels using the svgFilePath and the svgContent binding to overlay the text labels wherever they are needed.
Here is what that looks like and how did it:
My test svg just zipped
TextTest.zip (1.2 KB)
Create some index text labels
Create a snippet to read the index text
<Snippet id="SnippetLabel" xsi:type="session" type="IndexText" formatItem="IAT/Label.{1}" />
Greate the necessary bindings for the snippet and svgContent.
The source is a session variable which is used later to read each index text. After going through the snippet, the text is written into another session variable FromLabelText.
<Binding mode="twoWay">
<Source xsi:type="session" refId="svgContentText" attribute="value" />
<Target xsi:type="brease" contentRefId="HD_LS1_contentService3" widgetRefId="Paper1" attribute="svgContent" />
</Binding>
<Binding mode="oneWay">
<Source xsi:type="session" refId="LabelValue" attribute="value" />
<Target xsi:type="snippet" refId="SnippetLabel" attribute="value" />
</Binding>
<Source xsi:type="snippet" refId="SnippetLabel" attribute="value" />
<Target xsi:type="text" refId="Label" attribute="value" />
</Binding>
<Source xsi:type="text" refId="Label" attribute="value" />
<Target xsi:type="session" refId="FromLabelText" attribute="value" />
</Binding>
We need some session variables
<Variable name="Language" xsi:type="ANY_INT" value="0" />
<Variable name="LabelValue" xsi:type="ANY_INT" value="0" />
<Variable name="FromLabelText" xsi:type="ANY_STRING" value="" />
<Variable name="svgContentText" xsi:type="ANY_STRING" value="" />
And for the EventScript the following code
clientSystem.contentLoaded(function(e){
if (e.detail.contentId === 'HD_LS1_contentService3') {
var texts = [];
// Binding chain LabelValue→SnippetLabel→Label(text)→FromLabelText is async; step through via valueChanged
variables.FromLabelText.valueChanged(function(ev){
if (texts.length >= 3) { return; }
texts.push(ev.detail.newValue);
if (texts.length < 3) {
variables.LabelValue.setValueNumber(texts.length + 1);
} else {
variables.svgContentText.setValueString(buildLabelOverlay(texts[0], texts[1], texts[2]));
variables.LabelValue.setValueNumber(0);
variables.Language.valueChanged(function(e){
if (e.detail.newValue != e.detail.oldValue) {
var texts = [];
} else {
// Update paperW/paperH when Paper1 is resized; all positions and font size derive from these
var PAPER_W = 320;
var PAPER_H = 550;
// TextTest.svg viewBox dimensions and label rect centers (viewBox units)
var SVG_VB_W = 320;
var SVG_VB_H = 550;
var LABELS = [
{ x: 164, y: 86 },
{ x: 164, y: 266 },
{ x: 164, y: 448 }
function buildLabelOverlay(text1, text2, text3) {
var scale = Math.min(PAPER_W / SVG_VB_W, PAPER_H / SVG_VB_H);
var xOff = (PAPER_W - SVG_VB_W * scale) / 2;
var yOff = (PAPER_H - SVG_VB_H * scale) / 2;
var fontSize = Math.round(20 * scale);
var style = ' font-family="Arial" font-size="' + fontSize + '" text-anchor="middle" dy="0.35em" fill="#1a1a1a"';
var texts = [text1, text2, text3];
var result = '';
for (var i = 0; i < LABELS.length; i++) {
var px = Math.round(xOff + LABELS[i].x * scale);
var py = Math.round(yOff + LABELS[i].y * scale);
result += '<text' + style + ' x="' + px + '" y="' + py + '">' + texts[i] + '</text>';
return result;
The size for paper widget and svg loaded within are defined so the label coordinates are matching. Then the label coordinates, those I just read from the Inkscape’s cursor position when hovering over the center of the rectangle I want to place the label.
Every time the content is loaded or the language is changed the code changes the LabelValue which returns the index text per written into a text array.
That text array is the source for creating a string written into the svgContentText with the internal function using text and coordinates.
You didn’t say how many labels you have or if you are scaling the image in any way but hopefully gives you an example to start with.
