I am currently migrating a project from AS 3.0.90 to AS 4.12,
the CPU from an old 2005 family to a X20CP3687X
The machine has a PC attached that reads/writes data to the PLC via anonymous ftp, i.e. without a user or password.
I have no access to the PC executable, so I need the new PLC to enable anonymous ftp.
Do you know how to configure AS 4.12, AR J4.93?
I have tried the following, trying access using FileZilla client
Enabling ftp, but no user => no ftp acess (ECONNREFUSED)
Enabling ftp, creating a user without name or password => no ftp access (server responds “password required for user anonymous”)
Enabling ftp, creating a user “anonymous” without a password => compilation error in Automation Studio
All I need is the X20CP3687X to behave like the old CP360 with respect to ftp
EDIT: In the meantime I sniffed the communication using wireshark. The old application on the HMI PC sends an empty user, not anonymous.
I’m not sure how AS/AR 3.x behaved, but the documentation for AS/AR 4.x makes me think this isn’t possible. I see a note on the Help page for the FTP settings which says:
The FTP server can only be enabled if at least one user has been created
You could try creating a user just to enable the server, and then logging in with the anonymous user rather than the one you created. I see a note in a different section of the documentation which doesn’t sound promising, though this is related specifically to the Web Server:
An explicit username must be used in order to transfer data to the USER partition. This is not permitted to be “guest” or “anonymous”
Default AR means the AR BOOT mode which is not booted from the CF / internal flash memory, it’s just the dedicated hardware-integrated system for initial commissioning of the PLC - that’s nothing that can be used for normal runtime (you can think about “default AR” like more or less a “BIOS” of a PC).
Unfortunately I agree with Marcus: the “complete opened FTP door” from very old AR systems is not longer possible at all since years, and cannot be emulated / configured.
