Automation Studio 6 Project Clonning
Long story short I started a project with 3 different hardware configuration. Now hardware configuration (3) is no longer an option and option number 2 has seen the project take a completely different direction from option 1. So Instead of keeping both hardware configuration in the same project. I decided to split hardware config 1 and 2 in two separate project.
I first tried to SaveAs the project, then Save as ZIP, As soon as I delete one of the configuration I endup with 1400 errors where the/temp/ bitmaps can be found.
Is there an easy way to do this, what seems to be a simple task seems so complicated.
Any help would be appreciated
Do you use file references in your project? Have you tried deleting the Binaries and Temp folders after you delete the configuration?
Thank you Pavel, it seems that deleting the Binaries folder solved the issue. Thank you for your fast response really appreciated
