B+R and Injection mo(u)lding
Hello, I am a beginner with B+R. I am an injection moulding engineer. I am working my way through the TMs. I intend on completing the APROL TMs. I want to assess if B+R APROL is suitable for harvesting data from the IMM, creating a closed loop system where machine outputs drive the inputs.
Are you familiar with any B+R applications in injection moulding?
Is there a B+R library for moulding?
Any input is appreciated,
Eoin.
Hello and welcome!
Any closed loop heating process can make use of mapp Temperature.
Here’s a link to the Help documentation on it B&R Online Help
The mpTemp library contains premade function blocks for creating control zones, tuning, and controlling temperatures.
Hello Eoin, another injection moulding engineer here . I am not really familiar with APROL but there is a B&R library for injection moulding called mapp Plastics which is basically only for injection moulding machines, either electric or hydraulic machines.
Oscar.
Thanks everyone for responses.
can you mark the answer that helped you the most as a solution, or describe to us how did you solve it?
