Browse Path: OpcUa_any
Hello Experts,
I have External OPC UA server setup tested with UaExpert.
But i am not able to connect the same server in Automation studio with OpcUa_any device.
Getting below information on debugging.
I am not sure whether i have added correct browse path for the variable i wanted to read.
Variable attributes from UaExpert:
Browse path i have added in AS:
Please suggest way forward
Browse the node using OPCUA UAexpert client. The path must be complete.
nice example you can find here. How to communicate two controllers thought OPC UA
Hi, Thanks for the reply.
I have modified path but still not getting the value.
How to debug the issue.
your path is not complete. you must go from root down to your node.
example from link I have shared with you:
Just to add on to this, if one of the browse names that constitute the path has a special character in it, such as a “.”, you must insert a “&” escape character in front of it.
Source here.
