Can I Get USB Information?
Hello, I’m Choi. Thanks Always.
I am using the X20CP0484 CPU. Is there a way to get feedback on the storage capacity of a USB plugged into the CPU?
Thank you.
Hello Choi,
Im guessing you have already linked thje usb successully in your program.
If not, this sample should help:
Sample AsUSB
After you Linked your USB Device (DevLink) you should be able to get the Memory Information via DevMemInfo
It could be, that this is already part of the sampletask… I have not looked at it to be honest…
hope this helps
