I’m jumping in on this topic - I’d like to interact with an external OPC UA server using mappView. From what I understand, this should be possible, but I can’t find where to configure it. I’ve checked the AS Help and AS itself but haven’t had any luck. Can someone point me in the right direction? Thanks for your help,
Bernhard
Hi and welcome to the Community,
you can find an information in the online help.
Hi @Bernhard_Felber, I marked Pavel’s answer as the solution. Feel free to change it if you have additional questions or if it wasn’t the solution for you.
