Convert OPCM file to UAD file
Hi All! I need to convert a project (>6000 tags) from using OPC DA (OPCM file) to OPC UA (UAD file). Is anyone aware of a tool or script that has been developed to accomplish this?
The OPCM file has a path to each tag, where the UAD file is more of a hierarchical scheme with variables grouped and associated with each task and structure
OPCM:
UAD:
Hello Isaac, unfortunately there is no tool or script to convert this file as these are two completely different systems. You will have to create a new uad file for the OPCUa system.
Best regards, Sekic Manuel, HMI Support
