load.zip (32.4 KB)
I’m experiencing a very strange phenomenon with this one, the cpu takes up a lot every once in a while.
Hi Boyu,
with the given information it will be very hard to answer your question.
- Which hardware do you use?
- How often is the load that high?
- Is the duration of the peak always the same?
You can try to use the profiler to log the load profile more detailed. If you log a high load period you will be able to find the task class and the program responsible for the load peak.
The profiler is attached.
load.zip (32.4 KB)
The problem has been identified, we go through the network to read the file caused by the file is not obvious when the file is small, later more will have a big impact, so far we have found a way to circumvent it. Thank you.
