Data protection
Hi, I’m using mpdatarecorder and MpDataRegParX to store process data into a user partition on the CF in .csv format. I would like to protect the partition from any access with a password or to encrypt the data to avoid any data leakage.
Does exist a solution?
Thank you!
Hi Gianluca!
There is no encryption for CSV files.
But you can selected to be PDF de file format and in this case you can define a user password.
For more information check AS Help for mapp Data:
MpDataRecorder configuration
Hi Gianluca!
If the CF is not taken out for the PLC, hence the access to the CF is only through the FTP, then you can also add an user and password on the PLC’s configuration to protect the access.
For more information on FTP configuration:
FTP configuration
