Mpdatarecord / CSV file
Hi ( Again)..
I am trying to log some process data.
For this I can see that mpdatarecord should do the trick.
When I look at MpData - Data logging in the help file, the I loose the structure (I am a Newbie) .
Is there any that has a little simple working project they would share, so I can see how it functions in a working program ?
B.R. // Claus
There is a step by step getting started guide available in Automation Help. Have you tried to follow this?
Automation Help: mapp Data Getting Started
Thanks for the reply Tommi!
Yes. but I get a lot of errors (Newbie).
Not the best friend with the ladder editor, and there is a lot of koncepts /terms I have to learn (Done programming in Delphi before).
Claus
HI @Claus_Lind do you still need help with this topic? If you are having trouble following the examples in the Help, I think that it’s probably worth reaching out to a local B&R expert. They can either walk you through the example or provide training.
No I have a working “groundbase” now.
Wanted to share the project. But The file size seems to be to big.
I have some time after summer holiday (still working) where I will try it in a project.
