This is the current settings.
The code I have written is paste down below:
// Save Top Error Data into CSV file
IF DiagCpuIsARsim() OR DiagCpuIsSimulated() THEN
DataRecordFb.MpLink := ADR(TopError);
DataRecordFb.DeviceName := ADR(‘TopErrorSim’);
DataRecordFb.RecordMode := mpDATA_RECORD_MODE_TRIGGER;
DataRecordFb();
ELSE
DataRecordFb.DeviceName := ADR(‘AlarmSummary’);
DataRecordFb();
END_IF
DataLogRegPar[0].MpLink := ADR(TopError);
DataLogRegPar[0].Description := ADR('Module');
DataLogRegPar[0].PVName := ADR('AlarmControl:dataReg_Module');
DataLogRegPar[0]();
DataLogRegPar[1].MpLink := ADR(TopError);
DataLogRegPar[1].Description := ADR('Error Code');
DataLogRegPar[1].PVName := ADR('AlarmControl:dataReg_Code');
DataLogRegPar[1]();
DataLogRegPar[2].MpLink := ADR(TopError);
DataLogRegPar[2].Description := ADR('Error Description');
DataLogRegPar[2].PVName := ADR('AlarmControl:dataReg_Name');
DataLogRegPar[2]();
DataLogRegPar[3].MpLink := ADR(TopError);
DataLogRegPar[3].Description := ADR('Frequency');
DataLogRegPar[3].PVName := ADR('AlarmControl:dataReg_Count');
DataLogRegPar[3]();
// Start Recording
IF RTCtime_struct.hour = 23 AND RTCtime_struct.minute = 55 AND EDGEPOS(RTCtime_struct.second = 55) THEN
FOR d := 1 TO 300 DO
TopErrors[d].Total_Count := uint_totalCounter[d];
IF uint_totalCounter[d] > 0 THEN
TopErrors[d].Error_Module := str_Alarm[d].Module;
TopErrors[d].Error_Code := d;
TopErrors[d].Error_Name := str_Alarm[d].Error_Name;
ELSE
TopErrors[d].Error_Module := '';
TopErrors[d].Error_Code := 0;
TopErrors[d].Error_Name := '';
TopErrors[d].Total_Count := 0;
END_IF
END_FOR
Record_Trigger := TRUE;
END_IF
// Reset Value
IF RTCtime_struct.hour = 23 AND RTCtime_struct.minute = 59 AND EDGEPOS(RTCtime_struct.second = 55) THEN
FOR c:=1 TO 300 DO
uint_totalCounter[c] := 0;
TopErrors[c].Error_Code := 0;
TopErrors[c].Error_Module := '';
TopErrors[c].Error_Name := '';
TopErrors[c].Total_Count := 0;
END_FOR
END_IF
// Pass data into DataReg
IF Record_Trigger THEN
IF NextLine AND TopErrors[i_].Total_Count > 0 THEN
dataReg_Module := TopErrors[i_].Error_Module;
dataReg_Code := TopErrors[i_].Error_Code;
dataReg_Name := TopErrors[i_].Error_Name;
dataReg_Count := TopErrors[i_].Total_Count;
i_ := i_ + 1;
NextLine := FALSE;
ELSIF TopErrors[i_].Total_Count = 0 THEN
Record_Trigger := FALSE;
END_IF
END_IF
// byStep_Error Function start
IF DataRecordFb.Error = TRUE THEN
byStep_Error := 100;
END_IF
CASE byStep_Error OF
0:
IF (dataReg_Module <> '' AND dataReg_Code <> 0 AND dataReg_Name <> '' AND dataReg_Count <> 0) OR (NOT DataRecordFb.Record AND NOT DataRecordFb.Recording) THEN
// Can't overwrite the file name
// DataRecordFb.Info.CurrentFileName := 'TopError_202411.csv';
DataRecordFb.Trigger := TRUE;
byStep_Error := 1;
END_IF
IF currentDate <> gstr_Month THEN
byStep_Error := 3;
END_IF
1:
dataReg_Module := '';
dataReg_Code := 0;
dataReg_Name := '';
dataReg_Count := 0;
DataRecordFb.Trigger := FALSE;
IF DataRecordFb.Active THEN
DataRecordFb.Record := TRUE;
byStep_Error := 2;
END_IF
2:
IF DataRecordFb.Recording THEN
NextLine := TRUE;
byStep_Error := 0;
END_IF
3:
currentDate := gstr_Month;
DataRecordFb.Record := FALSE;
byStep_Error := 4;
4:
IF NOT DataRecordFb.Recording THEN
byStep_Error := 0;
END_IF
100:(*Error Handling*)
DataRecordFb.ErrorReset := TRUE;
IF DataRecordFb.Error = FALSE THEN
DataRecordFb.ErrorReset := FALSE;
byStep_Error := 0;
END_IF
END_CASE
Could anyone help me on this?
I just want it all to be in 1 file, and not have _1 _2
