Default client language in MappView
I was wondering how MappView decides what language to use as default when opening a client. It has nothing to do with which design language is chosen in the Project.language file nor the order they are in.
I know you can assign a language per user or the SetLanguage event binding, but I’m not using those and it seems it chooses one at random then?
The LanguageSelector widget does work properly though.
This is in AS 4.12.5.95 with MappView v 5.24.3
Hi Ruben,
you can set mapp View default language in Configuration View here:
Sincerly
Simon
