Estou com problemas ao execultar o zenon no apc 3100 pois ele necessita do pvi para comunicar com o plc b&r , tem algum aplicativo extra a ser instalado ou alguma licença especifica , pois o material que li não conseguir entender se precisa ou não .
you may need the PVI Runtime Enviornment which is part of the development Setup.
https://www.br-automation.com/de-de/downloads/software/automation-netpvi/pvi-development-setup/
Hello @Maiky!
Kindly let us know if @michael.bertsch has addressed to the question raised so that we can conclude on this for future reference.
Cheers,
Eren
closed due to inactivity
