Fsanitize option
Hi everyone,
Has anyone here tried using the fsanitize compiler option in Automation Studio? I’m looking for resources or materials on how to interpret the results, as they seem different from the examples I’ve found online. Any insights or documentation links would be greatly appreciated!
I’ve attached how I implemented this fsanitize setting and the results I received.
Thanks!
Hello Filip,
the GCC documentation states that this option must be used together with the linker clang. According to the GNU documentation in AS 6, however, the linker Ld is used. The linker clang is not supported as far as I know.
Thank you for your fast response.
HI Filip, is it your topic closed with this answer from Ludger, if so marked his reply as a solution.
