Go-to Logical View for Opened Tasks
It would be highly beneficial to have a “Go-to Logical View” function in Automation Studio that allows users to quickly locate a task within the Logical View tree.
Ex.
When a task is opened via search results, there is currently no direct way to reveal its position in the Logical View. Users must rely on the tooltip to identify the file path and then manually navigate through the directory structure, which is inefficient, especially in large projects.
If I understood correctly, you should be able to achieve this by enabling the Synchronization feature.
This can be enabled from the AS top menu View → Synchronize or the button in the toolbar
Thanks!! Shared with colleagues too
